john Payne Posted September 19, 2018 Share Posted September 19, 2018 I have a 2009 puma pick up with the pin/spring type but it will not engage to close ( It just happened out of the blue) The cable release from the cab works fine and opens up the hole in the striker plate It almost appears that the spring on the pin is too strong to push down Any ideas Please Quote Link to comment Share on other sites More sharing options...
western Posted September 19, 2018 Share Posted September 19, 2018 please give more info, what exactly are you needing info/help with ? Quote Link to comment Share on other sites More sharing options...
Scotts90 Posted September 19, 2018 Share Posted September 19, 2018 Bonnet catch at a guess. Lean harder!! Quote Link to comment Share on other sites More sharing options...
miketomcat Posted September 20, 2018 Share Posted September 20, 2018 The bonnet catch position is adjustable. Loosen it close the bonnet allow it to centre itself (you may need to help it) tighten and check. Mike Quote Link to comment Share on other sites More sharing options...
