discodave Posted December 20, 2006 Share Posted December 20, 2006 morning everybody. my disco's gonna be off road 6-7 days a week at work come mid january and although it shouldnt be extremely bad, there will most likely be some sections of rutted mud and fairly deep water. would you advise putting in all possible wading plugs and running breathers up into the engine bay, and is it ok to run the truck like this all the time. if so, any advice on where to buy and fitting? wont be deep enough to bother wi a snork (if it is i'll be turnin round and goin back) but i dont want to get water where it shouldnt be. ta. actually, i've just done a search and seen previous posts. damn, must always remember to do that first. cheers. DD Quote Link to comment Share on other sites More sharing options...
Matt Neale Posted December 20, 2006 Share Posted December 20, 2006 morning everybody. my disco's gonna be off road 6-7 days a week at work come mid january and although it shouldnt be extremely bad, there will most likely be some sections of rutted mud and fairly deep water. would you advise putting in all possible wading plugs and running breathers up into the engine bay, and is it ok to run the truck like this all the time. if so, any advice on where to buy and fitting? wont be deep enough to bother wi a snork (if it is i'll be turnin round and goin back) but i dont want to get water where it shouldnt be. ta. actually, i've just done a search and seen previous posts. damn, must always remember to do that first. cheers. DD Fit the genuine part wading plugs to the timing case and the bell housing. Remove them at least once a week and check for any oil deposits etc, then refit. Max wading depth (according to LR) without any further prep is roughly the top of the wheel rim - say about 18". You'll get the plugs (2 req'd) from any main dealer/LR supplier - they are a gen part. You don't want to leave mud trapped under the car for any length of time, so pressure wash the vehicle regularly - at least a couple of times a week if you're off road every day. Keep an eye on wheel bearings as any water getting past the seals will destroy them in no time. Matt Quote Link to comment Share on other sites More sharing options...
freeagent Posted December 20, 2006 Share Posted December 20, 2006 i'd grease the propshafts every couple of weeks aswell, will only take 5 mins to do, but make sure you've cleaned the grease nipples first as you could end up pushing dirt into the UJ..... as the others said, no harm in leaving the wading plugs in but remove them regularly just to make sure you haven't sprung a leak inside... it might be worth cheaking if you're breather tubes are clean and not blocked aswell... Quote Link to comment Share on other sites More sharing options...
Bush65 Posted December 21, 2006 Share Posted December 21, 2006 For both the bellhousing and timing cover, I fitted 1/4" bsp male to female elbows (very compact). Then screwed 1/4" bsp to 5/16" hose tails into the elbows, and ran clear hose to inline filters beside the brake booster. From the other side of the inline filters I ran another hose with a loop and breather hole. So I can leave this permanent, visually check for oil leaks and have provided breathers. Quote Link to comment Share on other sites More sharing options...
discodave Posted December 22, 2006 Author Share Posted December 22, 2006 For both the bellhousing and timing cover, I fitted 1/4" bsp male to female elbows (very compact).Then screwed 1/4" bsp to 5/16" hose tails into the elbows, and ran clear hose to inline filters beside the brake booster. From the other side of the inline filters I ran another hose with a loop and breather hole. So I can leave this permanent, visually check for oil leaks and have provided breathers. sounds good, do you have any pictures? Quote Link to comment Share on other sites More sharing options...
LS26 Posted December 22, 2006 Share Posted December 22, 2006 For both the bellhousing and timing cover, I fitted 1/4" bsp male to female elbows (very compact).Then screwed 1/4" bsp to 5/16" hose tails into the elbows, and ran clear hose to inline filters beside the brake booster. From the other side of the inline filters I ran another hose with a loop and breather hole. So I can leave this permanent, visually check for oil leaks and have provided breathers. Nice ideas! I particularly like the use of clear hose Rog Quote Link to comment Share on other sites More sharing options...
Bush65 Posted December 23, 2006 Share Posted December 23, 2006 sounds good, do you have any pictures? Just went out and took some for you. Quote Link to comment Share on other sites More sharing options...
discodave Posted December 23, 2006 Author Share Posted December 23, 2006 thanks for the pics, looks nicely done, think i'll have to give it a go. cheers. dave Quote Link to comment Share on other sites More sharing options...
discodave Posted December 26, 2006 Author Share Posted December 26, 2006 anyone know where to source bush65's breather pipe fittings in the uk? i've had a swatch on google and eblag and seen the hose tails but not those low profile male to female elbows, only bends which look a bit bulky Quote Link to comment Share on other sites More sharing options...
LR90 Posted December 26, 2006 Share Posted December 26, 2006 I'd trot up to hyphose and get some 1/4BSP fiittings with a push in hose connector but not sure how local that is to you? Must ask about the clear hose though, nice idea. Quote Link to comment Share on other sites More sharing options...
discodave Posted December 26, 2006 Author Share Posted December 26, 2006 thanks trev, i'm at my girlfriends place in skegness at the moment so i think it'd be more of a trek than a trot if you're down in hampshire. i dont really know this area or anyone in it (other than the missus) so finding anything in the area is a bit needle and haystacklike for me. i'll persevere with tinternet and try and find some mail order jobbies. cheers anyway DD Quote Link to comment Share on other sites More sharing options...
LR90 Posted December 26, 2006 Share Posted December 26, 2006 Give them a call in the new year http://www.hyphose.com/ if you can't find anything closer to home Quote Link to comment Share on other sites More sharing options...
lynall Posted December 29, 2006 Share Posted December 29, 2006 On my old TDI i went to a hydraulic supplier and got two 1/4 bsp taps look like small washing machine taps, screwed these into drain holes, off road switch them off, on road swith them open again easy. Lynall Quote Link to comment Share on other sites More sharing options...
discodave Posted December 29, 2006 Author Share Posted December 29, 2006 sounds even easier lynall. i like easy. nice 1 Quote Link to comment Share on other sites More sharing options...
