Ben696901 Posted January 10, 2019 Share Posted January 10, 2019 Hi everyone.i hope you can share your knowledge. I know people have brought this topic up before but I’m running out of ideas. My 300tdi defender doesn’t start that well. On start up it feels quite choked up and I try to clear it . Quite a lot of blue smoke comes out . When I drive off and it’s on run over on down hill it bellows blue smoke out but once warm it doesn’t do it. When accelerating doesn’t seem to do it , only when I lift off the throttle. I have replaced the piston rings and head gasket and homed the bores. New oil in. Would the only other things it could be are injectors or turbo seals or glow plugs? With it smoking so much people have said it wouldn’t be the valve stem seals. Thanks in advance Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted January 10, 2019 Share Posted January 10, 2019 Sounds like guides to me... Quote Link to comment Share on other sites More sharing options...
cackshifter Posted January 11, 2019 Share Posted January 11, 2019 I am with Bowie, check turbo and clean breathers while its apart though, it could be more than one thing. Quote Link to comment Share on other sites More sharing options...
Ben696901 Posted January 11, 2019 Author Share Posted January 11, 2019 Ok il have a look at the turbo and see if I can check the valve guides . Thank you to you both Quote Link to comment Share on other sites More sharing options...
cackshifter Posted January 12, 2019 Share Posted January 12, 2019 Sometimes the valve stem oil seals get blown off the guides, they obviously don't do much like that. Might be worth a peek under the rocker cover before a strip. You can change the seals with the head on, drawing of tool needed on this forum somewhere. Quote Link to comment Share on other sites More sharing options...
