petrolhead63 Posted January 22, 2019 Share Posted January 22, 2019 I have two jobs to sort. 1) the front passenger window has a runner problem, it rocks around and jams up....if this is common what is likely to be broken? I can purchase parts before stripping that way. any tips on how to take the door card off gratefully received too! 2) I have the aircon/automatic type heater controls in a millenium edition with a digital display. All the buttons under it for fan, outside temp etc have lost the night time dial illumination so can only be found by feel! how does the panel pull out and are there little bulbs in it? Thanks for any help. Quote Link to comment Share on other sites More sharing options...
sierrafery Posted January 22, 2019 Share Posted January 22, 2019 (edited) About the aircon buttons you'll understand how to remove it from minute 2 on https://www.youtube.com/watch?time_continue=160&v=savH5ne6M7k as about bulbs here are the codes for the bottom row you need the JWH100070 Edited January 22, 2019 by sierrafery Quote Link to comment Share on other sites More sharing options...
bear Posted January 22, 2019 Share Posted January 22, 2019 Here's a How To for the window regulator https://www.roverparts.com/resources/videos/repair-window-regulator-motor-discovery-ii/ HTH, Griff Quote Link to comment Share on other sites More sharing options...
petrolhead63 Posted February 11, 2019 Author Share Posted February 11, 2019 fantastic, thanks for both the help posts. Just sorted the new mot so onto the the other little jobs next. Quote Link to comment Share on other sites More sharing options...
petrolhead63 Posted February 13, 2019 Author Share Posted February 13, 2019 On 1/22/2019 at 3:41 PM, sierrafery said: About the aircon buttons you'll understand how to remove it from minute 2 on https://www.youtube.com/watch?time_continue=160&v=savH5ne6M7k as about bulbs here are the codes for the bottom row you need the JWH100070 Hi, so having looked at mine...all that illuminates is the LCD screen and one temperature control button (blue part). The bottom row not lit, the middle row under the lcd display not lit, and the 2nd temp control button not lit! I need an 850251, and the JWH100070. what illuminates the middle row under the LCD? Quote Link to comment Share on other sites More sharing options...
