Wheel bearing race sizes
Cornish Rattler
For most series there are two different sets.
The older one, which I think had two different bearings, and the new one, that has a pair of same sizes bearings.
Change over was June 1980, or thereabouts, but your axles, or stub axles may easily have been swapped any time.
This picture is of a new type stub axle (actually a stage one V8, but the stub is the same) and a 1972 sub axle, the newer one is the same diameter along the length (thicker).
I'll get the bearing numbers in a sec.
Assuming the stub is as original, then it's the two different bearings.
Try EAC for the parts, "shop for auto parts", I think they call the on line shop.
They do good quality.
Yeah its the actuel size i need as the fitting tool kit goes from 39mm-81mm and not sure if the kit will cover early series wheel bearing races :)
I see!
I can see the benefit for the seal, but the bearings are easy enough to fit. They are a loose interference fit in the hub, but just hand push on to the stub.
I just tap the bearings in with a very wide punch, little taps at 12, 4 and 7 o'clock and the bearing race goes in easy.
Dead easy to remove, too.
12 minutes ago, Gazzar said:
I see!
Yeah thats how i fit them but sometimes they can chip when tapping them in and for £15 i think the kit is worth getting
