sarfarm Posted February 24, 2019 Share Posted February 24, 2019 (edited) Has anyone actually removed these leaky units and replaced them with something else ?????? Edited February 24, 2019 by sarfarm Quote Link to comment Share on other sites More sharing options...
teabag Posted February 25, 2019 Share Posted February 25, 2019 Why go to the trouble of making something that’s water tight to replace the sunroofs, when all u have to do is replace one or both of the existing seals. Quote Link to comment Share on other sites More sharing options...
Richard Mills Posted February 25, 2019 Share Posted February 25, 2019 I fixed mine, just took them both out, cleaned up the seal and the roof and refitted using sealant, no more leaks. Make sure the drain holes are clear and work properly, they make a lot of difference. Quote Link to comment Share on other sites More sharing options...
teabag Posted February 25, 2019 Share Posted February 25, 2019 (edited) 50 minutes ago, Richard Mills said: I fixed mine, just took them both out, cleaned up the seal and the roof and refitted using sealant, no more leaks. Make sure the drain holes are clear and work properly, they make a lot of difference. Drain holes! For owners that open and tilt their sunroof while it’s covered with water, hence drains only at the front of the sunroof. 💦 Edited February 25, 2019 by teabag Spelling Quote Link to comment Share on other sites More sharing options...
ballcock Posted February 25, 2019 Share Posted February 25, 2019 As said, take them out clean them up and refit with a non-setting sealant similar to that used on caravan windows. Allows for the different expansion rates. Quote Link to comment Share on other sites More sharing options...
