boaterboy Posted August 15, 2019 Share Posted August 15, 2019 The a/c on my D2 has failed and requires a new condenser (leaking) - too costly for me to replace at the moment! The cabin heater and a/c dashboard controls are integrated. Is it ok for me to continue using the heater, please? Do I need to or can I isolate the a/c in any way? If it is ok to continue using the heater will any damage occur to the a/c system? Very many thanks for any help & advice, in anticipation. Quote Link to comment Share on other sites More sharing options...
bear Posted August 15, 2019 Share Posted August 15, 2019 Hi, As long as the AC is set to "Economy" then the ac clutch/compressor is switch off anyway. If you have lost ac fluid the compressor won't run anyway as a safety feature. I'm sure the heater works in conjunction with the cooling system so is therefore a seperate system. Do a search for RAVE, the LR manual, and you'll get all your answers there. HTH, Griff Quote Link to comment Share on other sites More sharing options...
boaterboy Posted August 15, 2019 Author Share Posted August 15, 2019 Thank you for your most speedy and very useful reply, bear. Much appreciated. Quote Link to comment Share on other sites More sharing options...
supaimpy Posted August 15, 2019 Share Posted August 15, 2019 just to be sure unplug the clutch wire on the compressor Quote Link to comment Share on other sites More sharing options...
boaterboy Posted August 16, 2019 Author Share Posted August 16, 2019 Please could you help me identify the clutch wire to which you refer, supaimpy? Quote Link to comment Share on other sites More sharing options...
bear Posted August 16, 2019 Share Posted August 16, 2019 Wiring shown here http://new.lrcat.com/#!/1232/37503/37504/2869 Griff Quote Link to comment Share on other sites More sharing options...
boaterboy Posted August 16, 2019 Author Share Posted August 16, 2019 Thank you for that, bear. It looks like a multi-pin connector? Will get to the car later to see. Do I need to identify a single lead (ie for the clutch) or can I just disconnect the connector complete, please? Quote Link to comment Share on other sites More sharing options...
boaterboy Posted August 17, 2019 Author Share Posted August 17, 2019 Or, can I just remove fuse number 6, 10 amps, air conditioning (see attached - I hope it transmits - never posted a scan before!) to isolate the compressor clutch instead of unplugging the clutch wire as suggested above? Scan taken from Discovery handbook. Thank you for your ongoing help, all. It's very much appreciated. Quote Link to comment Share on other sites More sharing options...
bear Posted August 18, 2019 Share Posted August 18, 2019 I guess that would work, also see if there is a relay. But as I mentioned previously, if there is no air con refrigerant in the system it shuts off anyway. Griff Quote Link to comment Share on other sites More sharing options...
