Jonty1951 Posted November 19, 2019 Share Posted November 19, 2019 Hi just purchased 2003 defender 110 estate cant find OBD, tc/abs lights on ,any ideas thanks 1 Quote Link to comment Share on other sites More sharing options...
crwoody Posted November 19, 2019 Share Posted November 19, 2019 (edited) It should be on the front edge of the seat box, between the passenger seat and cubby box. It’s wiring goes through a grommet in the cover plate beneath the cubby box and disappears into the loom above the transfer box. Edited November 19, 2019 by crwoody Quote Link to comment Share on other sites More sharing options...
Jonty1951 Posted November 19, 2019 Author Share Posted November 19, 2019 Thanks looked there to no avail think it might be a case of it being moved elsewhere to avoid theft ? Quote Link to comment Share on other sites More sharing options...
V8 Freak Posted November 19, 2019 Share Posted November 19, 2019 Please confirm it's a TD5 and do you have a wire popping up through the access plate under the centre seat / cubby box. (Near the front of the panel, left side of vehicle) If there is a collection of shielded wires there follow to the end and hopefully they will have your OBD socket on there. If no wires popping up through the panel they may have dropped it under the panel, above the transfer box, for additional security ! Quote Link to comment Share on other sites More sharing options...
Jonty1951 Posted November 20, 2019 Author Share Posted November 20, 2019 Hi all after much searching it had been moved and cable tied to a loom under the floor,thanks for all your help now on to diagnosing the ABS problem Quote Link to comment Share on other sites More sharing options...
paime Posted November 21, 2019 Share Posted November 21, 2019 What's the ABS problem? Quote Link to comment Share on other sites More sharing options...
