Bowie69 Posted February 28, 2020 Share Posted February 28, 2020 Oh, and metric fasteners. But the same? No. Quote Link to comment Share on other sites More sharing options...
Ex Member Posted February 28, 2020 Share Posted February 28, 2020 12 minutes ago, Bowie69 said: So it's the same, but different, which is what I said, I think? It is not a high spec Dana 60 whatever way you roll it Using metric fasteners for the crown wheel (12 mm bolts versus 1/2") does not affect the strength, which is the discussion here. The crown wheel and pinion are never upgraded when people build up Dana 60s in the US. They install a locker with side gears designed for the larger shafts and put in larger shafts. The stuff that is there in a stock Salisbury is the same and just as strong. 1 Quote Link to comment Share on other sites More sharing options...
