bushwhacker Posted April 3, 2020 Share Posted April 3, 2020 Hi should the part shown be free to turn or tight? What does it do? Quote Link to comment Share on other sites More sharing options...
steve b Posted April 3, 2020 Share Posted April 3, 2020 It's the balance weight and should be fixed I think , will check mine romorrow. cheers Steve b 1 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted April 3, 2020 Share Posted April 3, 2020 The weight in question has two positions when loose it does a lot of small circular motions for sanding / finishing but you can also turn it into the centre shaft to lock it up the DA then acts more like a grinder for taking lots of material off quicker try it in both positions and you will see what I mean so it should be turntable to allow whatever function is required if the centre Allen bolt is very slack nip it up but should still be able to turn once nipped regards Stephen 1 Quote Link to comment Share on other sites More sharing options...
