Td5 radiator
Hi all looking for a bit of help for the stepson as I don’t know a lot about td5’s  , he’s got an early td5 2000 and the rads knackered so ordered a new one from britcar , rad came a nissens jobbie but it’s modified it fits all td5’s but the bottom two outlets on the rad are blocked and there’s a small ali thing you put in the fuel cooler ,
has anyone had to do this with there rad and did you bother with the thing in the cooler above ?
 Any help much appreciated as always cheers Ian.
Nissens not Nissan, Apparently Land Rover altered them , there’s a tech article on the web somewhere the stepson found it and when I looked there’s a thread on here about it it blocks the bottom two outlets off from the fuel cooler and you put that ali bit into the end of the fuel cooler too restrict the flow .
