Jonnym82 Posted April 29, 2020 Share Posted April 29, 2020 Hi all, Will coolant leak from the water pump if the engine is not running? Struggling to identify where the leak is coming from and found my way back to the water pump. Cheers Quote Link to comment Share on other sites More sharing options...
ballcock Posted April 29, 2020 Share Posted April 29, 2020 It could be, if you are not using it regular you could dry it off and put something there to absorb water. you can also buy an ultra-violet dye to add to the system and trace with an ultra-violet lamp. I have made up a spare cap at times with a tyre valve to pressurise the system cold to look for leaks. Quote Link to comment Share on other sites More sharing options...
Jonnym82 Posted April 29, 2020 Author Share Posted April 29, 2020 Yes, was looking at doing that myself. The leak takes a route where it just clings to everything until it finally drops off the hose above front diff. Seems impossible to find the cause without a bit of help. Quote Link to comment Share on other sites More sharing options...
western Posted April 29, 2020 Share Posted April 29, 2020 Water pump has a hole on bottom of the case where it's shaft fits, to allow a tell tale leak if the shafts seals are leaking, Also ensure the hoses clips are fully tight. Quote Link to comment Share on other sites More sharing options...
reb78 Posted April 29, 2020 Share Posted April 29, 2020 My water pump on the 200tdi went just like this, but there was a tell tale smear of blue down the front of the engine where the antifreeze had dried off and left deposits. It will get blown about a bit where the fan pushes air back. Best time to look is after a run when the system is hot and still pressurised. I had a further weep on the thermostat housing bypass hose. It was old/original pipe and the connector had rusted a little on the pipe to the back of the head allowing it to leak a little. It was hard to find as the drip was onto the exhaust manifold stud beneath so it dried when running, but left the bolt head wet when it was cool enough! Quote Link to comment Share on other sites More sharing options...
Jonnym82 Posted April 29, 2020 Author Share Posted April 29, 2020 Thanks chaps. The coolant seems to be coming from water pump. Is it possible that it just needs a gasket or will it need a swap? Quote Link to comment Share on other sites More sharing options...
western Posted April 29, 2020 Share Posted April 29, 2020 Have a look under the pulley shaft part of the body, use a small mirror & see if the tell tale hole has fluid dripping from it. Quote Link to comment Share on other sites More sharing options...
reb78 Posted April 29, 2020 Share Posted April 29, 2020 Yep ^ as Ralph says - the hole will have crusty antifreeze in it/show a visible leak if it is coming from there. Quote Link to comment Share on other sites More sharing options...
