Robrayc Posted May 6, 2020 Share Posted May 6, 2020 Hello All. My 2004 Disco 2 TD5's tachometer does not work. I hear it could be the display dial itself that maybe at fault or is it the originating signal. Any suggestions? Quote Link to comment Share on other sites More sharing options...
Richard Mills Posted May 6, 2020 Share Posted May 6, 2020 Hi there, Check the contacts on the back of the alternator, the older versions feed the tachometer signal from there. A corroded tag will stop it working. Quote Link to comment Share on other sites More sharing options...
sierrafery Posted May 7, 2020 Share Posted May 7, 2020 (edited) Hi. Disregard the alternator. On the D2 the tachometer is managed by the ECM based on CPS input. Plug in a dedicated tester and if it shows the rpm the problem is on the signal path to the IP or the gauge Edited May 7, 2020 by sierrafery Quote Link to comment Share on other sites More sharing options...
Escape Posted May 7, 2020 Share Posted May 7, 2020 ^^ what he says. Check the output from the ECU with diagnostics, if that's OK look at the wiring and last resort the dash itself. Quote Link to comment Share on other sites More sharing options...
Robrayc Posted May 10, 2020 Author Share Posted May 10, 2020 Thank you all for your advice. I will try to get a tester on confirm the problem. Quote Link to comment Share on other sites More sharing options...
