western Posted May 12, 2020 Share Posted May 12, 2020 Has anyone fitted one of these Ford hazard switch into a 90/110. I've been on Google but can't find a decent Ford wiring diagram giving info on the wire colour codes & what they do & which pin they go to on the rear of the switch. I'm thinking of adding it to the top right of my Mudstuff console by extending the existing wiring from switch on lower right of steering column in my 110. Quote Link to comment Share on other sites More sharing options...
Roverdrive Posted May 12, 2020 Share Posted May 12, 2020 Not exactly what you were after but I found this link to a Durite push button hazard switch with a circuit diagram. Working on my phone so not very clear but I saw references to similar terminal numbers https://www.arc-components.com/0-484-50-12v-hazard-warning-light-switch-8148.html Quote Link to comment Share on other sites More sharing options...
western Posted May 12, 2020 Author Share Posted May 12, 2020 Cheers for the link, it does look similar in the connections markings. I've added it to my bookmarks for later reading. Quote Link to comment Share on other sites More sharing options...
Snagger Posted May 13, 2020 Share Posted May 13, 2020 Red must be a feed from the flasher unit, and black is almost certainly the earth for the internal bulb. That would leave the others feeding off to the individual indicator units. It should be simple to confirm that with a basic electrical tester. Quote Link to comment Share on other sites More sharing options...
western Posted May 13, 2020 Author Share Posted May 13, 2020 looking at the wire entry into the rubber socket. its not marked, only the rear pin end of the switch is marked, might have a fiddle with a test light & 12v power supply later. Quote Link to comment Share on other sites More sharing options...
