MagicMatt Posted May 28, 2020 Share Posted May 28, 2020 I’m rebuilding a 2.25 diesel swb series 3 from what is basically boxes of bits. Just looking to route the clutch pipe. Am I running it under or over the bell housing? cheers for any help matt Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted May 28, 2020 Share Posted May 28, 2020 Over the top of the bell housing regards Stephen Quote Link to comment Share on other sites More sharing options...
Snagger Posted May 28, 2020 Share Posted May 28, 2020 There is a tab bracket on the bulkhead to attach the top end of the flexible hose. Right hand drive models have a bracket fixed to the block’s rear cam gallery cover plate for the lower end of the flexible hose. A rigid pipe then runs over the flywheel housing and down to the cylinder. You can also do it the Defender way of a rigid pipe all the way to the inboard side of the left foot well and run a flexible hose to the cylinder. Quote Link to comment Share on other sites More sharing options...
MagicMatt Posted May 28, 2020 Author Share Posted May 28, 2020 Thanks guys, thought it probably was, just wasn’t 100%. Quote Link to comment Share on other sites More sharing options...
