Engine oil
Simon_CSK
Need do an oil change on a TDV8 Range Rover L322 and know that I need 5w30 synthetic. There is cheap oil at £16 per 20l right up to expensive oils what is the difference. I would assume that there must be some.
Yes. The difference is the price. Look at your handbook and find the spec you need, and as long as it states it on the label, its fine.
Make sure you get the right one, as it can affect the Cats and any DPF in the long run, among many other things.
