Rear de mist switch
A latching switch does what it says and latches in the ON position until it is operated again when it goes back to OFF. So no, a latching switch wouldn't run through a timer relay. These have a MOMentary switch that just pulses a signal to them in order for them to click ON for the timed period.
Oops  😊
That’s what I actually meant. Really should proof read before I send
appreciate the very quick reply 👍
next question will probably be hazard lights. All 3 of the switches in this panel just crumbled while I was removing dash
 I have seen landymanlukes write up, so will try decipher using that
thanks again
Told you i would be back
can I change my disintegrated hazard switch for one of these ??
And if so ,, using Lukes write up how the hell would I hook it up??
i bet Ed Poore is glad he’s on the road today.
thanks
info on diagram below looks a bit Chinglish ??
Well this won't be much help but my hazard switch (now using a Carling Contura V) has the following connections:
G - IGN switched +12v
P - Permanent +12V
GW - to RH side indicators
GR - to LH side indicators
LGN - to turn switch common
LG - to flasher relay
plus an earth and illumination
Not sure if your switch will easily swap in.
