Kill switch
BulBoys
Hi all, rolled my car earlier, well flipped in the side..
It's a Td5
Wouldn't start after, I believe there is a kill switch.. How do I unkill the switch..
Also I did switch off engine fairly quickly, few seconds at max. Do I need to worry bout any oil from the sump or something..
Yes - you need to worry a bit about oil etc.
Once vehicle is back on it's wheel, check all fluids and see if you can turn the engine "by hand" just to make sure....
What caused the roll if I may ask ?
