ianmayco68 Posted October 1, 2020 Share Posted October 1, 2020 Hi all, does anyone know if you need to change the rear output housing on a 4HP24 V8 box out of a P38 to accept a LT230 transfer box rather than the Borg Warner one ? Asking as I’ve seen one for sale. cheers Ian Quote Link to comment Share on other sites More sharing options...
smallfry Posted October 2, 2020 Share Posted October 2, 2020 Yes you do. Also need to change the output shaft OR cut it off, drill a hole in the end, tap it, then buy and adaptor shaft and bolt. Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted October 2, 2020 Author Share Posted October 2, 2020 Cheers smallfry, new about the shaft but hadn’t heard about the rear housing. cheers Ian Quote Link to comment Share on other sites More sharing options...
Tobias Posted October 4, 2020 Share Posted October 4, 2020 On 10/2/2020 at 2:14 AM, smallfry said: Yes you do. Also need to change the output shaft OR cut it off, drill a hole in the end, tap it, then buy and adaptor shaft and bolt. Could you please give more info? Who sells the adaptor shaft? Cut how much? Anything else I want to know? Thanks Tobias Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted October 4, 2020 Author Share Posted October 4, 2020 Ashcroft Transmissions sells the shafts https://www.ashcroft-transmissions.co.uk/diy-rebuild-kits/zf-rebuild-kits/ftc5090.html that's as much info as I can give at the minute , I can put a pic up of the rear housing that I've just bought when it comes if you would like ? cheers Ian Quote Link to comment Share on other sites More sharing options...
