ballcock Posted December 5, 2020 Share Posted December 5, 2020 As Snagger said there should be something stopping the bottom pointy end moving forward until it's lifted up the slot which stops it collapsing. If there is nothing there you could fit a bolt out of the bracket to locate it. I'll have to see what's on mine. I bought a kit from Nige years ago but have not got around to fitting it yet as I have no problem with my scissor system. Quote Link to comment Share on other sites More sharing options...
Chambo110 Posted December 5, 2020 Author Share Posted December 5, 2020 30 minutes ago, ballcock said: As Snagger said there should be something stopping the bottom pointy end moving forward until it's lifted up the slot which stops it collapsing. If there is nothing there you could fit a bolt out of the bracket to locate it. I'll have to see what's on mine. I bought a kit from Nige years ago but have not got around to fitting it yet as I have no problem with my scissor system. Ah that would explain any pics would be cracking Quote Link to comment Share on other sites More sharing options...
Snagger Posted December 5, 2020 Share Posted December 5, 2020 37 minutes ago, ballcock said: As Snagger said there should be something stopping the bottom pointy end moving forward until it's lifted up the slot which stops it collapsing. If there is nothing there you could fit a bolt out of the bracket to locate it. I'll have to see what's on mine. I bought a kit from Nige years ago but have not got around to fitting it yet as I have no problem with my scissor system. On the SIII, it’s just part of the bracket that bolts to the wing, bent inward 90 degrees and pressed hard against the front edge of the bottom of the leg, preventing the bottom end rotating forward (and thus the middle backward toward the bulkhead). A bolt with a nut and large washer each side of the bracket or any other vertical surface would do the same job. Quote Link to comment Share on other sites More sharing options...
western Posted December 5, 2020 Share Posted December 5, 2020 These might help https://www.defendersource.com/threads/bonnet-stay-hood-support.54653/ https://forums.lr4x4.com/topic/99149-bonnet-stay-prop-what-one/ Quote Link to comment Share on other sites More sharing options...
Chambo110 Posted December 6, 2020 Author Share Posted December 6, 2020 Sussed it. bottom pointy end was bent over somehow?? all straight again now and it locks if knocked out of alignment. As per below thanks chaps snagger i will do the gas struts upgrade eventually. I’ll let ya know when. If you still want my old we can sort it then ta 1 Quote Link to comment Share on other sites More sharing options...
