gruntus Posted December 16, 2020 Share Posted December 16, 2020 Hi All, I've bought a bonnet gas ram kit from Hybrid (nice bit of kit) that I am going to fit this weekend ahead of doing my timing belt and decided to fit a bonnet safety hook MUC6457 for good measure "just in case" the bonnet releases whilst I'm going at (....ahem...) Mach 3 and the bonnet pops up. Does anyone have a pic of one fitted to their bonnet? Thanks in advance. 😊 G 🙂 Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted December 16, 2020 Share Posted December 16, 2020 Not mine but found this on the net , have you not got one fitted already ? 1 Quote Link to comment Share on other sites More sharing options...
gruntus Posted December 16, 2020 Author Share Posted December 16, 2020 Thanks Ian, 👍 The original slam panel/grill arrangement (1986) had the lockable latch that swung up and locked it in place. I changed it to a "blingy" grill and just a bonnet pull during its "refit". The slam panel has the cut out for the hook to latch in to. That bonnet (presuming a 300TDi) looks a bit different to my original bonnet. I have 4 square brackets (2 either side of the catch) which are spot welded in place and think probably had rubbers fitted to previously. I may need remove the one above the cut out in the slam panel and fit rivnuts for it to bolt it to. Thanks again. 🙂 G Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted December 16, 2020 Share Posted December 16, 2020 If you can wait till the weekend I can take some better pictures and get some measurements for you from my project which is a 300tdi , yes you’ll need to fit rivnuts original has captive nuts in the bonnet panel. Quote Link to comment Share on other sites More sharing options...
gruntus Posted December 16, 2020 Author Share Posted December 16, 2020 Thanks Ian that would be greatly appreciated! 🙂 Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted December 16, 2020 Share Posted December 16, 2020 No worries mate , will post them up Friday or Saturday for you. Quote Link to comment Share on other sites More sharing options...
western Posted December 16, 2020 Share Posted December 16, 2020 Took these, 1st on my old bonnet showing the 3 rivnuts & the others from my current Td5 bonnet Quote Link to comment Share on other sites More sharing options...
western Posted December 16, 2020 Share Posted December 16, 2020 Items 7,8,9,10,11 & 12 fit on slam panel so the safety hook has something to catch on if bonnet pops open Quote Link to comment Share on other sites More sharing options...
western Posted December 16, 2020 Share Posted December 16, 2020 Safety hook & associated parts items 13,14,15 & 16 Quote Link to comment Share on other sites More sharing options...
gruntus Posted December 16, 2020 Author Share Posted December 16, 2020 Thanks Ralph, I'm fairly sure the slam panel I have which I don't think was original has the part 12 fitted (will check tomorrow). BTW what was wrong with your first bonnet? Just a little bit of rust worm infestation......🤣 Cheers 👍 G 🙂 Quote Link to comment Share on other sites More sharing options...
western Posted December 16, 2020 Share Posted December 16, 2020 It had a bad case of tinworm, the front inner frame where the bonnet spring section is,was just about hanging on but wouldn't shut & lock properly & it had 2 dents in the raised areas on the outer skin, so it got replaced by a great condition Td5 bonnet which I had painted in the correct colour & fitted it. Quote Link to comment Share on other sites More sharing options...
