Lloydie Posted February 27, 2021 Share Posted February 27, 2021 My Td5 rear suspension keeps going down but not all of the time. When parked it sometimes remains up. When it deflates after parking it will usually inflate and drive normally when the engine is started with no problem for miles. It will deflate when idle, and when travelling on a bumpy road Quote Link to comment Share on other sites More sharing options...
Blanco Posted February 27, 2021 Share Posted February 27, 2021 Bag leaks can be like that,.... the leak is often on the worn area where it folds under, only leaking if exposed when parked. You need to track it down and fix / replace asap, over working the compressor is going to shorten it's life dramatically. Soapy water and jack it up slightly should clarify what's what for you. Quote Link to comment Share on other sites More sharing options...
bear Posted February 27, 2021 Share Posted February 27, 2021 +1 on Blanco's advice. How old are the bags? Anything over about 5 yrs and it's ther likely cause. Treat them like any service item that will need to be replaced evey so often. Griff Quote Link to comment Share on other sites More sharing options...
