monkie Posted March 30, 2021 Share Posted March 30, 2021 As a follow on from my rewire project on my 110, I want to get myself a set of gauges to monitor the engine better. I am starting with an acurate coolant temperature guage (Stack professional from Merlin motorsport). I will initially be fitting this to my 19J, but I will soon be fitting Ian's Defender spec 200 Tdi. Two questions. (1) Will the sender fit/what sender do I need in terms of thread size? (2) Will the sender required for the 19J be the same as that required for the 200Tdi in terms of thread size? https://www.merlinmotorsport.co.uk/p/stack-water-temperature-gauge-40-120-degrees-c-st33 Quote Link to comment Share on other sites More sharing options...
western Posted March 30, 2021 Share Posted March 30, 2021 Defender spec 200tdi coolant temp sender is PRC8593 5/8unf thread, I can't remember what thread it is on the 19J engine & the temp sender lives at back of cylinder head not at the stat housing. for 19J there are 2 part numbers PRC2505 or PRC6663 both as item 1 in screen shot of parts page. Discovery 200tdi is 1/8npt IIRC. Quote Link to comment Share on other sites More sharing options...
monkie Posted March 30, 2021 Author Share Posted March 30, 2021 Thanks Ralph, how do people put the Stack sender in the head for 200Tdi? The sender supplied is 1/8"NPT with adapters for 3/8"NPT and 1/2" NPT. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted March 30, 2021 Share Posted March 30, 2021 Make an adapter out of the original sender. Mo Quote Link to comment Share on other sites More sharing options...
western Posted March 30, 2021 Share Posted March 30, 2021 When I fitted the Td5 instrument pack I made the 200tdi sender PRC8593 into a adaptor so the outside had the 5/8 UNF thread & inside was threaded with a 1/8 NPT tap to accept the new sender. Quote Link to comment Share on other sites More sharing options...
western Posted March 30, 2021 Share Posted March 30, 2021 2 hours ago, monkie said: Thanks Ralph, how do people put the Stack sender in the head for 200Tdi? The sender supplied is 1/8"NPT with adapters for 3/8"NPT and 1/2" NPT. As in my reply above or buy from --- https://www.merlinmotorsport.co.uk/p/thread-adaptor-5-8unf-male-to-1-8npt-female-adp-5-8unfa 1 1 Quote Link to comment Share on other sites More sharing options...
monkie Posted March 30, 2021 Author Share Posted March 30, 2021 Great info. Thanks Ralph. 1 Quote Link to comment Share on other sites More sharing options...
monkie Posted March 30, 2021 Author Share Posted March 30, 2021 What EGT guages are folk running, where have people put the probe in relation to the exhaust turbine? Quote Link to comment Share on other sites More sharing options...
monkie Posted April 2, 2021 Author Share Posted April 2, 2021 On 3/30/2021 at 6:29 PM, western said: As in my reply above or buy from --- https://www.merlinmotorsport.co.uk/p/thread-adaptor-5-8unf-male-to-1-8npt-female-adp-5-8unfa As usual @western I'm indebted to your sage advice. Perfect fit on the 19j cylinder head 1 Quote Link to comment Share on other sites More sharing options...
western Posted April 2, 2021 Share Posted April 2, 2021 Glad it fitted OK, Quote Link to comment Share on other sites More sharing options...
