biffer4240 Posted April 3, 2021 Share Posted April 3, 2021 hi guys i was wondering if any one has any measurements for welding in new engine mounts to fit a 300tdi engine into what i think is classic range rover chassis many thanks Quote Link to comment Share on other sites More sharing options...
RRC200Tdi Posted April 3, 2021 Share Posted April 3, 2021 Can you use your transmission and transfer case mounts to locate the engine or are you doing something non-standard? Quote Link to comment Share on other sites More sharing options...
biffer4240 Posted April 4, 2021 Author Share Posted April 4, 2021 16 hours ago, RRC200Tdi said: Can you use your transmission and transfer case mounts to locate the engine or are you doing something non-standard? no as it been cut down to 88 inch so was wondering if any one has a distance from front of chassis ect as i know will have to make a short rear prop but been told the front of all chassis are the same up to front outriggers Quote Link to comment Share on other sites More sharing options...
Tim2809 Posted April 5, 2021 Share Posted April 5, 2021 You can get template that bolts on and then place mount on chassis and weld on. Will try and find a link Quote Link to comment Share on other sites More sharing options...
Tim2809 Posted April 5, 2021 Share Posted April 5, 2021 https://www.mdengineering.co.uk/shop/miscellaneous/chassis-bracket-kit-300tdi/ give them a call, they may sell just the jig Quote Link to comment Share on other sites More sharing options...
biffer4240 Posted April 10, 2021 Author Share Posted April 10, 2021 On 4/5/2021 at 1:30 PM, Tim2809 said: https://www.mdengineering.co.uk/shop/miscellaneous/chassis-bracket-kit-300tdi/ give them a call, they may sell just the jig thankyou this is just what im looking for really helps Quote Link to comment Share on other sites More sharing options...
Ohlins Posted June 1, 2021 Share Posted June 1, 2021 Or you can buy them ready made....... https://www.steveparkers.com/product/engbkts300-weld-on-chassis-engine-mounting-brackets-300tdi-4cyl-v8-chassis/ :) Quote Link to comment Share on other sites More sharing options...
