jamesledingham Posted January 18, 2007 Share Posted January 18, 2007 How much would you expect to pay for a respray plus preperation? And can anyone reccomend anyone in the Gloucestershire/Worcestershire area? Quote Link to comment Share on other sites More sharing options...
Happyoldgit Posted January 18, 2007 Share Posted January 18, 2007 Depends what vehicle but I would say at least a grand. Cost can be minimised if you remove trim etc. Quote Link to comment Share on other sites More sharing options...
jamesledingham Posted January 18, 2007 Author Share Posted January 18, 2007 A 90 van back and a 90 van with windows Quote Link to comment Share on other sites More sharing options...
techtone Posted January 18, 2007 Share Posted January 18, 2007 Last quote I had was £700 +vat for: 90 roof 90 sides (Glazed) 90 rear wings Thats when I when I decided to learn to spray! (good enough for what I need!) Tony Quote Link to comment Share on other sites More sharing options...
jamesledingham Posted January 18, 2007 Author Share Posted January 18, 2007 How easy is spraying...? Quote Link to comment Share on other sites More sharing options...
dred90 Posted January 18, 2007 Share Posted January 18, 2007 How easy is spraying...? As with most things you learn from your mistakes - best not to practice on your range rover sport!! It's the prep work which is most time consuming - also usefull to have a dry / preferably heated indoor dust free space to do it in.. Quote Link to comment Share on other sites More sharing options...
Happyoldgit Posted January 18, 2007 Share Posted January 18, 2007 How easy is spraying...? Spraying is relatively straight forward if you have the gear, it's the prep work that takes the time and to a large extent determines the quality of the finish. If you have the time (and space) to practice beforehand then you should be able to make a presentable job - but don't underestimate what's involved. Quote Link to comment Share on other sites More sharing options...
michael calvert Posted January 19, 2007 Share Posted January 19, 2007 Spraying is relatively straight forward if you have the gear, it's the prep work that takes the time and to a large extent determines the quality of the finish. If you have the time (and space) to practice beforehand then you should be able to make a presentable job - but don't underestimate what's involved. one advantage for both Doing it yourself:- CAN SAY I APINTED THAT Someone else doing it:- IF YOUR NOT HAPPY WITH QUALITY OR ITS NOT RGHT - ITS UP TO THEM TO PUT IT RIGHT. patience and time is the key to it in the prep, dont think that'l do - it wont dont skimp on paint or equipment but dont buy the top of the range if you paint once in a blue moon. Quote Link to comment Share on other sites More sharing options...
