o_teunico Posted December 17, 2021 Share Posted December 17, 2021 Hi all, What's de meaning of those label/stickers in engine bay? Today I have seen a Suzuki at a garage. They removed the sticker and cleaned with thinner "so it could pass the MoT test". Quote Link to comment Share on other sites More sharing options...
Maverik Posted December 17, 2021 Share Posted December 17, 2021 It's to do with the emissions. 1 Quote Link to comment Share on other sites More sharing options...
o_teunico Posted December 17, 2021 Author Share Posted December 17, 2021 Ok, thanks. I have searched spanish ITV (our MoT test equivalent) and aparently, if emission sticker is not present, general emission limits will rule, based on plate age. This limits are generally higher than those on sticker. Quote Link to comment Share on other sites More sharing options...
pat_pending Posted December 18, 2021 Share Posted December 18, 2021 (edited) From the UK testers manual... The maximum smoke level limit will be the level displayed on the manufacturer’s plate; or where there is no manufacturer’s plate information: For vehicles first used before 1 July 2008, the maximum level is: 2.5m-1 for a non-turbocharged engine 3.0m-1 for a turbocharged engine For vehicles first used between 1 July 2008 and 31 December 2013 the maximum level is 1.5m-1 for all engines. For vehicles first used on or after 1 January 2014 the maximum level is 0.7m-1 for all engines. And... Manufacturer’s plate means either the VIN plate or a separate plate or sticker, which is likely to be within the engine compartment. The plate or sticker may be marked 24 R followed by a number to indicate the smoke limit (such as 0.24 in the example below). It’s usually displayed in a box and often positioned in the bottom right corner of the VIN plate. Currently it's left for testers to find the plate and apply the correct limit to the test, some plates have been removed either deliberately or where body repairs have been done or are just not obvious. As this leads to an inconsistent level of testing, DVSA is rumoured to be working on a database of manufacturers limits that would be applied automatically by "connected" equipment, that sends the results of emissions and brake tests live to DVSA during testing. There may be a lot of vehicles suddenly failing their test. Edited to add... Connected emissions testers are already here, but currently only on new installations/equipment, I'm not sure if the database exists yet Edited December 18, 2021 by pat_pending 2 Quote Link to comment Share on other sites More sharing options...
smallfry Posted December 18, 2021 Share Posted December 18, 2021 As said, this sticker SHOULD be on the bonnet slam panel, but on most cars and vans now, it is also on the VIN sticker on the door jamb Quote Link to comment Share on other sites More sharing options...
