Stevov8 Posted February 1, 2022 Share Posted February 1, 2022 hi could some one please tell me if they no if the d2 td5 manual gearbox will fit the v8 please Quote Link to comment Share on other sites More sharing options...
Escape Posted February 1, 2022 Share Posted February 1, 2022 It wont fit, the input shaft is different, both diameter and length if I remember. They can be mixed and matched, but it's a lot of work. Quote Link to comment Share on other sites More sharing options...
Stevov8 Posted February 1, 2022 Author Share Posted February 1, 2022 Ah ok , chuffin typical can buy a td5 box for couple hundred quid but a v8 box is up round the thousand mark Quote Link to comment Share on other sites More sharing options...
ashtrans Posted February 4, 2022 Share Posted February 4, 2022 we have V8 pinions in stock if you want to swap it Quote Link to comment Share on other sites More sharing options...
Carloz Posted February 6, 2022 Share Posted February 6, 2022 You need a V8 bellhousing too. And that makes a cheap diesel box still expensive to use on a V8. Only the old VM diesel LT77 manual box can be used with the original input-shaft (spindle?). But still you need to swap the bellhousing. Quote Link to comment Share on other sites More sharing options...
