Turbocharger Posted January 23, 2007 Share Posted January 23, 2007 Which alternator do I have, before I order new innards? Is it even a standard LR unit? I remember machining chunks out of an alternator once, but that may have been for my NAD. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted January 24, 2007 Share Posted January 24, 2007 Looks physically very close to the stock 65A jobby on my RR. What innards do you need - the reg packs can be bought separately, and brushes often stick and can be encouraged back out with some jiggling & WD40. Quote Link to comment Share on other sites More sharing options...
Andy Posted January 24, 2007 Share Posted January 24, 2007 looks like the stock Lucas 65A one that used to be on my Disco too Quote Link to comment Share on other sites More sharing options...
GBMUD Posted January 24, 2007 Share Posted January 24, 2007 Yep, change the thing on the left in the bottom pic. Three screws, one spade terminal and Bobs your uncle. Be careful not to exert force when fitting the new one or you will break the brushes off. Chris Quote Link to comment Share on other sites More sharing options...
Turbocharger Posted January 24, 2007 Author Share Posted January 24, 2007 Excellent, new regulator on order from SimonB. Can I fit it with the alternator still in place? Quote Link to comment Share on other sites More sharing options...
GBMUD Posted January 24, 2007 Share Posted January 24, 2007 I can on my 200Tdi. Looking at the picture, it looks possible - you may have smaller hands than me. Chris Quote Link to comment Share on other sites More sharing options...
Andy Posted January 24, 2007 Share Posted January 24, 2007 should be able too, my mate used to have to do his regulary when the brushes stuck. whenever his brushes stuck his voltmeter dropped but the charge light never came on, which is why he'd fitted the voltmeter. from memory the three retaining bolts are 5.5mm heads. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted January 24, 2007 Share Posted January 24, 2007 You will probably find, if the brushes have stuck, that you can "fix" it with WD40 + fiddling, the brushes spring back out after you dissolve the mud that clogs them up. Dad's alt has been "fixed" about 3 times this way Quote Link to comment Share on other sites More sharing options...
GBMUD Posted January 25, 2007 Share Posted January 25, 2007 When the brushes stick you get (a predictable) 0V. I always unstick mine by removing the brush pack and bathing the brushes in water and then excercising them in and out to clear the mud while flushing them in the water. I get precisely the same symptoms as described by Andy - only the volt meter gives it away. John's problem is with the internals of the regulator. Chris Quote Link to comment Share on other sites More sharing options...
Turbocharger Posted January 25, 2007 Author Share Posted January 25, 2007 0V? I'm getting 16V, so I suspect the 'regulating' bit rather than the brush bit... Quote Link to comment Share on other sites More sharing options...
GBMUD Posted January 25, 2007 Share Posted January 25, 2007 John's problem is with the internals of the regulator.Chris Chris Quote Link to comment Share on other sites More sharing options...
