Paddy Posted July 26, 2022 Share Posted July 26, 2022 Before I break it, how do I remove the cover to replace a bulb? There isn’t a retaining screw holding the cover on, so does it slide or pull off? It doesn't want to do either at the moment. Quote Link to comment Share on other sites More sharing options...
L19MUD Posted July 26, 2022 Share Posted July 26, 2022 It pulls off. There are two plastic pins towards either end in the middle horizontally. I find it best to wiggle them up and down whilst pulling to try not to break them They only seem to come in 2 options, stuck on and nothing would shift them or falling off! Quote Link to comment Share on other sites More sharing options...
Paddy Posted July 26, 2022 Author Share Posted July 26, 2022 Bulb gone so need to get in to it, ill try hot water, plus gas and fingers crossed. I least I know which way to pull now, thanks. Quote Link to comment Share on other sites More sharing options...
western Posted July 26, 2022 Share Posted July 26, 2022 Smal flat blade between wing & rear of the len, ease it out, there are 2 pins thst push into plastic grommets in the wing, then rotate & pull the bulb holder out to swap the bulb. My 110 has the same repeater indicators Quote Link to comment Share on other sites More sharing options...
Paddy Posted July 27, 2022 Author Share Posted July 27, 2022 Hmm, orange lens cover has come away leaving the black plastic backing plate in place. Moss and “jelly” growing inside !! Orange cover is suffering UV deterioration with loads of cracks. I’ll fit 2 new ones just need to sort a part number. Thanks both for help. Part # PRC7044 1 Quote Link to comment Share on other sites More sharing options...
western Posted July 27, 2022 Share Posted July 27, 2022 Correct PRC7044 Quote Link to comment Share on other sites More sharing options...
