Bigj66 Posted August 29, 2022 Share Posted August 29, 2022 Does anyone have a single cab 110 HCPU and could take some measurements of the tub for me? Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted August 29, 2022 Share Posted August 29, 2022 I *think* the 130 hicaps are different, which may give you another option? Quote Link to comment Share on other sites More sharing options...
Bigj66 Posted August 29, 2022 Author Share Posted August 29, 2022 1 hour ago, Bowie69 said: I *think* the 130 hicaps are different, which may give you another option? I’ve not seen a 130 single cab just the 110 and 127. I’ve only been able to find a double cab 130 with the smaller tub. I read somewhere that the 110 and 127 HCPU single cabs share the same tub with the difference being made up around the truck cab. Not sure if this is correct though hence the query. Reason for asking is that I’m considering fitting a canopy to my Sankey tub (127) but there don’t seem to be many advertised compared to the 110 canopies. Quote Link to comment Share on other sites More sharing options...
muddy Posted August 29, 2022 Share Posted August 29, 2022 There are only two sizes of HCPU tub 110 and 127/130 (both actually 127' wheelbase) Both tubs are the same size from the wheel arch backwards just 110 ones have an extra 9" in the front IIRC. 1 1 Quote Link to comment Share on other sites More sharing options...
Bigj66 Posted August 29, 2022 Author Share Posted August 29, 2022 1 minute ago, muddy said: There are only two sizes of HCPU tub 110 and 127/130 (both actually 127' wheelbase) Both tubs are the same size from the wheel arch backwards just 110 ones have an extra 9" in the front IIRC. Turns out mine is a 110 tub and not the 127 as I initially thought🤦♂️. Explains a lot and problem solved 👍 2 Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted August 29, 2022 Share Posted August 29, 2022 Thanks @muddy 1 Quote Link to comment Share on other sites More sharing options...
