RizzleKicks Posted December 23, 2022 Share Posted December 23, 2022 Evening Folks, The 2004 manual 🦛 has decided to blow luke warm air & the Temp gauges rises no more than 1/4. Mechanic has said that the Thermostat has failed and is in the stuck open position. Now I have read up and see there is an easy fix to this , see the link below. My question is has anyone tried this Fix of so how easy is it and is there any pics ? https://www.ebay.co.uk/itm/325053759548?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=gRLtOZl9TLS&sssrc=2349624&ssuid=im--QYK9SL-&var=&widget_ver=artemis&media=COPY TIA RizzleKicks Quote Link to comment Share on other sites More sharing options...
smallfry Posted December 24, 2022 Share Posted December 24, 2022 Seems ridiculously expensive to me. Changing the standard one is not that difficult. The main problem with this though, is that a thermostat "in line" like this, requires a flow of water to it (bypass) for it to work. As this effectively blocks a hose how it any hot water going to get to the thermostat capsule ? I would hope it has a bypass channel or at the very least a jiggle pin. Before buying, I would check with the seller. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted December 27, 2022 Share Posted December 27, 2022 Didn't you post this thread already? Quote Link to comment Share on other sites More sharing options...
CookieSthAust Posted October 30, 2023 Share Posted October 30, 2023 Just changed my thermostat on the weekend, not that bad to do. Get yourself a ratchet and standard 1/4” ring spanners and a 1/4” drive for the drill (this goes in to the ratchet spanner to undo a couple of the housing bolts) a proper coolant hose clamp pliers will also make life easier undo the aircon hose for easier access, no need to remove engine mounts etc, finely but doable. order a new thermostat housing and thermostat, it will come with the seal. You will also need a new o ring for the coolant pipe that bolts in to the housing. allow most of the day for the first one lol Quote Link to comment Share on other sites More sharing options...
