Gazzar Posted January 7, 2023 Share Posted January 7, 2023 What's good? Bad? Value? I'll be working on a Salisbury axle or three. £150 buys a hydraulic set of all sorts. Unbranded. Quote Link to comment Share on other sites More sharing options...
hurbie Posted January 7, 2023 Share Posted January 7, 2023 (edited) if i had to do a salisbury again , i would buy a "clamshell" bearing puller . with a normal puller it is a real pain to get the bearings off , in the end i had to make a adapter plate to use with a "normal" puller because they were that tight . Edited January 7, 2023 by hurbie 1 Quote Link to comment Share on other sites More sharing options...
Gazzar Posted January 8, 2023 Author Share Posted January 8, 2023 Those look ideal. I've never liked the abuse approach to removing bearings. I'll buy a set of these, I think. Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted January 8, 2023 Share Posted January 8, 2023 5 minutes ago, Gazzar said: Those look ideal. I've never liked the abuse approach to removing bearings. I'll buy a set of these, I think. Must admit I also quite like the look of them, I have various pullers and some that slide behind narrow gaps, but nothing like them A future lathe project me thinks Regards Stephen 1 Quote Link to comment Share on other sites More sharing options...
Gazzar Posted January 8, 2023 Author Share Posted January 8, 2023 I was thinking that. But I think I'll buy them. Not good enough on the lathe, by a long shot! Quote Link to comment Share on other sites More sharing options...
