madcanuck Posted January 27, 2007 Share Posted January 27, 2007 Good day all, Does anybody have information as to what the rev/rpm limits would be for a V8 NA? The only data I have is as follows Max pwr @ 4000 rpm, Tq @ 2500 rpm. I'm setting up a VDO marine tacho need to make sure I have the correct range. Thanks, Quote Link to comment Share on other sites More sharing options...
Ex Member Posted January 29, 2007 Share Posted January 29, 2007 Most people get 6000 rpm tachs. The valves float and power drops like a brick before the mechanicals give out. 5500 rpm redline should be OK. Quote Link to comment Share on other sites More sharing options...
madcanuck Posted January 30, 2007 Author Share Posted January 30, 2007 Most people get 6000 rpm tachs. The valves float and power drops like a brick before the mechanicals give out. 5500 rpm redline should be OK. Thanks, will range mark mine accordingly, much appreciated! T Quote Link to comment Share on other sites More sharing options...
Bull Bar Cowboy Posted January 30, 2007 Share Posted January 30, 2007 In their standard form 5500 is about tops ………… after that the hydraulic lifters begin to pump and hold the valves open, also the bottom end is not bullet proof at above that sort of rpm ………… so if you regularity want to go to 6K + then fit Rhoads anti pump lifters, and cross bolt the bottom end ……… if you want to go beyond that, then the engine can be made to go up 8K ……… but here you are looking at significant £££ mods….. cross bolted block, lightened flywheel, fully balanced bottom end, solid lifters etc, etc, In reality you will probably never need to push it beyond 5K in normal use. Ian Quote Link to comment Share on other sites More sharing options...
madcanuck Posted January 30, 2007 Author Share Posted January 30, 2007 In their standard form 5500 is about tops ………… after that the hydraulic lifters begin to pump and hold the valves open, also the bottom end is not bullet proof at above that sort of rpm ………… so if you regularity want to go to 6K + then fit Rhoads anti pump lifters, and cross bolt the bottom end ……… if you want to go beyond that, then the engine can be made to go up 8K ……… but here you are looking at significant £££ mods….. cross bolted block, lightened flywheel, fully balanced bottom end, solid lifters etc, etc, In reality you will probably never need to push it beyond 5K in normal use. Ian Thanks Ian, I think I'll stick with reality, my simple little beast should be just fine. 8K with one of these, why???? Wouldn't it be better to use a newer tech engine or a big block chev? T Quote Link to comment Share on other sites More sharing options...
Bull Bar Cowboy Posted January 30, 2007 Share Posted January 30, 2007 Yes you would think that would be more sense …… but the RV8 was very light (all alloy) and easy to tune ………… therefore it quickly became a favorite with the standing ¼ mile guys ………. I guess now time has marched on and some of the true yank beefy engines are now more widely available at reasonable cost. Ian Quote Link to comment Share on other sites More sharing options...
madcanuck Posted January 30, 2007 Author Share Posted January 30, 2007 Yes you would think that would be more sense …… but the RV8 was very light (all alloy) and easy to tune ………… therefore it quickly became a favorite with the standing ¼ mile guys ………. I guess now time has marched on and some of the true yank beefy engines are now more widely available at reasonable cost. Ian I had heard/read that the 3.5 was actually an Oldsmobile design Please say it isn't so! They probably died when they saw the dual carb install! Tracy Quote Link to comment Share on other sites More sharing options...
western Posted January 30, 2007 Share Posted January 30, 2007 The Rover V8 was originally a Buick design, bought by Rover for Range Rover & used by others such as TVR until they built thier own V8's. Quote Link to comment Share on other sites More sharing options...
Ex Member Posted January 31, 2007 Share Posted January 31, 2007 Here is some reading. Quote Link to comment Share on other sites More sharing options...
