simonpelly Posted June 12, 2023 Share Posted June 12, 2023 Hi Folks, Defender 110 300 Tdi The connector that goes onto the thermostat sensor at the RHS of the cylinder head (not the one on the top) - a single wire. Anybody know where to source a connector? Got a new loom and the connector is too big for it. Thanks, Simon... Quote Link to comment Share on other sites More sharing options...
western Posted June 13, 2023 Share Posted June 13, 2023 Ask @PaulMc Quote Link to comment Share on other sites More sharing options...
PaulMc Posted June 14, 2023 Share Posted June 14, 2023 The proper connector YPC10132 is not something that I've ever seen anywhere else - The connecting post on the sensor is shown as a 4mm terminal. Retroanaconda used one of the pre-insulated female bullets on his TD5 instrument pack conversion - http://www.retroanaconda.com/landrover/2009/10/installing-defender-td5-gauges-into-a-200tdi300tdi/ https://forums.lr4x4.com/topic/88114-rv8-temp-gauge-sender/ Personally, I'd use one like this - https://www.autosparks.co.uk/electrical-components/bullets-connector-sleeves/4mm-female-bullet-cover-pack-of-10 1 1 Quote Link to comment Share on other sites More sharing options...
simonpelly Posted June 16, 2023 Author Share Posted June 16, 2023 @PaulMc Thanks for the information. Sourced some new bullet connectors as suggested. Will let you know how that goes. Thanks, Simon.. Quote Link to comment Share on other sites More sharing options...
simonpelly Posted June 17, 2023 Author Share Posted June 17, 2023 (edited) @PaulMc Thanks again for the information. New bullet connectors arrived - ended up getting ones which are 3.9mm. Managed to scavenge the older connector plastic housing which fitted nicely and finished off with some heat shrink wrap. Edited June 17, 2023 by simonpelly 2 Quote Link to comment Share on other sites More sharing options...
PaulMc Posted June 17, 2023 Share Posted June 17, 2023 That looks like a good job 👍 Quote Link to comment Share on other sites More sharing options...
