Stellaghost Posted July 9, 2023 Share Posted July 9, 2023 Got a 13500lb Rhino winch with the trailer I've just bought, brand new still in the box, wire rope and remote control Are these winches any good, was thinking of fitting it onto the back of Sid instead of the ancient warn m8000 that's used as the rear winch Regards Stephen Quote Link to comment Share on other sites More sharing options...
bishbosh Posted July 10, 2023 Share Posted July 10, 2023 Paging @Nonimouse... Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted July 24, 2023 Author Share Posted July 24, 2023 I have a question I'm hoping some of you electronically gifted gentlemen can answer My Rhino winch remote function when I initially use it, it will only run for a couple of seconds then stop, this goes on for a couple of minutes then the remote system works absolutely fine, it's like it needs to warm up, any ideas what the problem could be Regards Stephen Quote Link to comment Share on other sites More sharing options...
bishbosh Posted July 24, 2023 Share Posted July 24, 2023 Wild guess but I’d say flat batteries. It could be your hand warmth is just tipping the remote battery into the green zone after you’ve e been holding it for a while? Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted July 24, 2023 Author Share Posted July 24, 2023 31 minutes ago, bishbosh said: Wild guess but I’d say flat batteries. It could be your hand warmth is just tipping the remote battery into the green zone after you’ve e been holding it for a while? That's what I thought, but no difference after putting in new batteries, both remotes do exactly the same, puzzling Regards Stephen Quote Link to comment Share on other sites More sharing options...
