hurbie Posted July 11, 2023 Share Posted July 11, 2023 hello all , question about the mounting off the flywheel housing on a 11L (200tdi defender spec) , in the workshop manual it state's to put a bead off sealant around the back off the block to mount the flywheel housing , in the parts manual there's a gasket mentioned (ERR1440) , is the sealant a modification from the gasket ? or do you use a gasket with a extra bead off sealant ? Quote Link to comment Share on other sites More sharing options...
western Posted July 11, 2023 Share Posted July 11, 2023 I just used the gasket between block & flywheel housing, no need for sealant. Item 19 in diagram https://new.lrcat.com/#!/1228/13789/16348/1274/16576 Quote Link to comment Share on other sites More sharing options...
hurbie Posted July 11, 2023 Author Share Posted July 11, 2023 this is the text from the manual flywheel housing.pdf Quote Link to comment Share on other sites More sharing options...
muzaz Posted July 11, 2023 Share Posted July 11, 2023 I put sealant on both the block, and the housing. Not sure there was any need to, but I don't think it will hurt anything. I hate oil leaks! Quote Link to comment Share on other sites More sharing options...
ped Posted July 11, 2023 Share Posted July 11, 2023 i used sealant with the gasket when i fitted one Quote Link to comment Share on other sites More sharing options...
hurbie Posted July 12, 2023 Author Share Posted July 12, 2023 got a reaction from a facebook group : Richard Hall Early flywheel housings had a circular recess which needs to be filled with sealant. If the flywheel housing has no recess it should be fitted "dry" using gasket ERR1440 which has preformed sealant beads on it. If you buy ERR1440 and it does not have the sealant beads that is because it is cheap rubbish. I use Elring gaskets which are the same material and construction as the original LR ones. Quote Link to comment Share on other sites More sharing options...
