andy.cowman Posted January 31 Share Posted January 31 Hello! I have a genuine 200tdi 1993 defender 90. I have a donor X5 3.0d.... you can probably see where I am heading All the kits for engine mounts etc talk about the 300tdi, so my question is are the standard engine mount positions for the 300tdi the same as a 200tdi? Thanks! Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted January 31 Share Posted January 31 No. Different design and position of mounts. The transmission is also mounted in a different position on the two variants. @Mo Murphy recently completed this conversion on the same spec of vehicle, and so will be able to advise on the types of mounts needed. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted January 31 Share Posted January 31 57 minutes ago, andy.cowman said: Hello! I have a genuine 200tdi 1993 defender 90. I have a donor X5 3.0d.... you can probably see where I am heading All the kits for engine mounts etc talk about the 300tdi, so my question is are the standard engine mount positions for the 300tdi the same as a 200tdi? Thanks! Andy, are you using the 6 speed auto ? Mo Quote Link to comment Share on other sites More sharing options...
andy.cowman Posted January 31 Author Share Posted January 31 24 minutes ago, Mo Murphy said: Andy, are you using the 6 speed auto ? Mo Hi Mo, Yes the 6 speed ZF auto will be used, any tips gratefully received Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted January 31 Share Posted January 31 OK Andy With the M57 and 6 speed auto the gearbox / transfer box mounts will go in the same place they are now which allows you to keep your propshafts. The engine mounts go where they land once your back end is located. I've used House of Torque (who are really supportive of the conversion community) for all parts excepting the mounts and adapter which were out of stock at the time and were sourced from MW (who are not). https://mwmachines.co.uk/shop/m57n-6-speed-automatic-engine-mount-kit This is a really nicely engineered and fabricated kit, easy to fit and works well using 300tdi rubbers. Select pre 300 and bolt on gearbox mounts in the drop down menus. I do have a build thread in the Members Vehicle section. HTH Mo Quote Link to comment Share on other sites More sharing options...
andy.cowman Posted January 31 Author Share Posted January 31 2 hours ago, Mo Murphy said: OK Andy With the M57 and 6 speed auto the gearbox / transfer box mounts will go in the same place they are now which allows you to keep your propshafts. The engine mounts go where they land once your back end is located. I've used House of Torque (who are really supportive of the conversion community) for all parts excepting the mounts and adapter which were out of stock at the time and were sourced from MW (who are not). https://mwmachines.co.uk/shop/m57n-6-speed-automatic-engine-mount-kit This is a really nicely engineered and fabricated kit, easy to fit and works well using 300tdi rubbers. Select pre 300 and bolt on gearbox mounts in the drop down menus. I do have a build thread in the Members Vehicle section. HTH Mo Thanks Mo, Great info, particularly about House Of Torque being supportive. Will certainly go toward them, I am not in a desperate rush so wil just start collecting what I need that isn't on the X5 already. I found your thread earlier and had a good read! Many thanks Quote Link to comment Share on other sites More sharing options...
