pinny Posted February 10, 2007 Share Posted February 10, 2007 i replaced my cat with a defender front pipe in december oviously this has no flexy pipe inline talking to another disco owner he is convinced this will snap anybody had this problem of pipe fracturing snapping cheers chris Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted February 10, 2007 Share Posted February 10, 2007 The flexy thingy is there to cut down on vibration only. You should be fine with the solid pipe. The flexy connections also tend to leak and break so that is a problem you won't have any more Quote Link to comment Share on other sites More sharing options...
RRX Posted February 10, 2007 Share Posted February 10, 2007 Replaced mine with a defender one and had no problems Quote Link to comment Share on other sites More sharing options...
Pete Attryde Posted February 11, 2007 Share Posted February 11, 2007 I guess if your exhaust was rigidly mounted to the rest of the car the engine vibration would probably break something however the exhaust system is (or should be) rubber mounted so the vibration will just shake the whole thing. Also if this was going to happen all the defenders that use the same downpipe would also be snapping them. Just my 2p's worth, Pete. Quote Link to comment Share on other sites More sharing options...
pinny Posted February 11, 2007 Author Share Posted February 11, 2007 cheers guys thats cleared up a few things and put my mind at rest Quote Link to comment Share on other sites More sharing options...
