Divster Posted February 21, 2007 Share Posted February 21, 2007 Can anyone give me the part no for the diff gasket for a late 110 axle (post salisbury). I've trawled through all of my stuff and can't seem to find it. It's definately different to the standard rover diff gasket (3916???) Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted February 21, 2007 Share Posted February 21, 2007 I've looked on my microcat and it doesn't show a gasket... well, not that i can find. maybe just some silicone gasket stuff will do the job? Quote Link to comment Share on other sites More sharing options...
Divster Posted February 21, 2007 Author Share Posted February 21, 2007 I've looked on my microcat and it doesn't show a gasket... well, not that i can find.maybe just some silicone gasket stuff will do the job? Thats the conclusion I was starting to come to. Quote Link to comment Share on other sites More sharing options...
Phil Hancock Posted February 21, 2007 Share Posted February 21, 2007 Its sili**** on late(thin flange) 200tdi disco axles. Quote Link to comment Share on other sites More sharing options...
mmgemini Posted February 21, 2007 Share Posted February 21, 2007 Yes it's supposed to be sill**** but I use a gasket. Series type or Range Rover will do Easier to wait until Ralph comes on line rather than empty my spares box in the Land Rover. mike FOAK Knickers I can cause trouble in an empty house !!! Quote Link to comment Share on other sites More sharing options...
western Posted February 21, 2007 Share Posted February 21, 2007 Sorry for being late, was compliling my CV & a job application letter -- hopefully I'll be moving up the ladder at work, anyway back to LR stuff EPC only tells me these--------- gasket RTC1139 for 110/130 Salisbury rear axle gasket 7316 for Diff assembly to chassis number KA930455 if Microcat doesn't list one then I suspect it uses a silicone sealant probably STC611 ----- HYLOMAR 2000 as used on 200Tdi sump/ladder frame. HTH Quote Link to comment Share on other sites More sharing options...
Divster Posted February 22, 2007 Author Share Posted February 22, 2007 Sorry for being late, was compliling my CV & a job application letter -- hopefully I'll be moving up the ladder at work, anyway back to LR stuffEPC only tells me these--------- gasket RTC1139 for 110/130 Salisbury rear axle gasket 7316 for Diff assembly to chassis number KA930455 if Microcat doesn't list one then I suspect it uses a silicone sealant probably STC611 ----- HYLOMAR 2000 as used on 200Tdi sump/ladder frame. HTH Well, I went for a generic RTV sealant. Time will tell Quote Link to comment Share on other sites More sharing options...
