scottydo Posted September 30, 2005 Share Posted September 30, 2005 The 90s engine(200tdi) wont turn off when the key is switched to the off posistion so i have to stall it so it will stop running. Anybody know whats going on there? Quote Link to comment Share on other sites More sharing options...
siggy Posted September 30, 2005 Share Posted September 30, 2005 stop solenoid it has a little pin, turn off ignition pin drops and cuts off fuel probably sticking easy enough to remove clean and put back just be careful of all the little bits and springs or dependant on cost just replace stop solenoid. Quote Link to comment Share on other sites More sharing options...
scottydo Posted September 30, 2005 Author Share Posted September 30, 2005 and were does the stop soleniod live? Quote Link to comment Share on other sites More sharing options...
siggy Posted September 30, 2005 Share Posted September 30, 2005 on top of the fuel injector housing thingy (wasit that delivers the fuel to each cylinder injector) should have a wire going to it with ignition on remove wire and you should here clunk and touch another clunk this is the solenoid working if you don't here anything possible it munched ^^^^ sorry for the technical stuff but totally brain dead at the mo Quote Link to comment Share on other sites More sharing options...
western Posted September 30, 2005 Share Posted September 30, 2005 Stop solenoid on the rear upper part of the injection pump just above the 4 fuel pipes to the injectors, you'll see a single wire with a female spade or ring terminal on it, to remove the solenoid take off the small nut [iIRC 8mm & the terminal tag] a 24mm spanner will fit BUT it's a swine to get on, about 1/4 to 1/2 turn at a time, when undo watch for the small spring and plunger inside, don't drop these, make sure there spotlessly clean, flush some diesel through by working the lift pump priming handle and refit all the parts, reconnect and test, if it happens again get the pump checked/tested, the cam/roller inside pick up on each other and create swarf slithers and this problem. Item 15 on this parts cat picture Quote Link to comment Share on other sites More sharing options...
siggy Posted September 30, 2005 Share Posted September 30, 2005 what ralph put so elequently above is what i said (just no so elequently) Quote Link to comment Share on other sites More sharing options...
western Posted September 30, 2005 Share Posted September 30, 2005 More reading www.lrenthusiastforum.com/ubbthreads/showflat.php?Cat=&Board=UBB7&Number=201940&page=&view=&sb=&o=&vc=1 & www.lrenthusiastforum.com/ubbthreads/showflat.php?Cat=&Board=UBB7&Number=81209&page=&view=&sb=&o=&vc=1 & www.lrenthusiastforum.com/ubbthreads/showflat.php?Cat=&Board=UBB7&Number=87671&page=&view=&sb=&o=&vc=1 Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted September 30, 2005 Share Posted September 30, 2005 and were does the stop soleniod live? er Peterborough ? I'll get me coat Nige Quote Link to comment Share on other sites More sharing options...
