96 300TDI - Steaming Oil Filler, Knocking noise and smoke
tpk241
Hi All,
Hope someone can help me diagnose the problem i have.
Coming back from sodbury couple of weeks ago near to home the discovery started making a faint knocking / grinding noise. I took it easy to get home and parked up. After coming back from holiday and working on disco today I started it to turn the wheels full lock and engine stalled.
Symptoms now are:
Eventually started whilst giving it gas, knocking noise evident, lots of smoke and wont idle needs gas to run.
So I switched it off straight away. BTW the engine is a defender with about 100,000 on it.
Inpspected engine & removed rocker cap, lots of steam/smoke (not sure) ... Removed belts to check wheels, all moved ok.
I fear the worst, someone please HELP !
Thanks in advance
TPK
Hi is it 300TDi defender eng in a disco ?
smoke/steam from rocker cover immediately on start up suggests blown head gasket.. is it really a "knocking" or more of a banging? How's the water level (300tdi check header tank and at thermostat housing) .They usually idle still if head gasket is gone though.
........however metallic knocking & won't idle suggests cam belt may have slipped a tooth, when was cam belt last done?
the grinding noise you mentioned on the way back from sodders also suggests cam belt . with the rocker cover off did all the push rods look straight & all the valve stem caps in place?
some food for thought maybe :)
Steveb
