tpk241 Posted May 14, 2007 Share Posted May 14, 2007 Hi All, As many others have probably had this problem please help !!! On doing a cambelt change I need to loosen the injector sprocket (3 10mm bolts) one of which is rounded ... Can anyone post a link or enlighten me to this technique ? Many thanks TPK Quote Link to comment Share on other sites More sharing options...
Les Henson Posted May 14, 2007 Share Posted May 14, 2007 Use a 3/8" socket - this is slightly smaller than 10mm, so might make the difference. You will probably have to knock it on with a hammer, so be careful. Les Quote Link to comment Share on other sites More sharing options...
BogMonster Posted May 14, 2007 Share Posted May 14, 2007 And use a six point socket not a conventional 12 pointer. Quote Link to comment Share on other sites More sharing options...
tpk241 Posted May 15, 2007 Author Share Posted May 15, 2007 Thanks all .. In the end i used an easy-out stud extractor .. which snapped !!! But it gave me some purchase to use screwdriver and hammer to tap it round .... six sided sockets only on the new bolt i feel ! Quote Link to comment Share on other sites More sharing options...
