rekab69 Posted May 18, 2007 Share Posted May 18, 2007 Hi Guys, I have a Defender 110 2000 rear axle (Rover type) would this fit a 93 200 Disco....?? Cheers db Quote Link to comment Share on other sites More sharing options...
LR90 Posted May 18, 2007 Share Posted May 18, 2007 If Rover (and you say it is as apposed to a salisbury) then yes. Just change the spring seats to fit the smaller diam disco springs. If you're running alloys you might need to just check the drive flanges for clearance. Quote Link to comment Share on other sites More sharing options...
rekab69 Posted May 18, 2007 Author Share Posted May 18, 2007 If Rover (and you say it is as apposed to a salisbury) then yes. Just change the spring seats to fit the smaller diam disco springs.If you're running alloys you might need to just check the drive flanges for clearance. Thanks.... db Quote Link to comment Share on other sites More sharing options...
BogMonster Posted May 19, 2007 Share Posted May 19, 2007 Hi Guys,I have a Defender 110 2000 rear axle (Rover type) would this fit a 93 200 Disco....?? Cheers db Unless it is off a Wolf either it isn't a Rover axle or it isn't 2000, because the Rover type 110 axles with the Wolf/P38a diff weren't introduced until 2002 model year so late calendar year 2001. Quote Link to comment Share on other sites More sharing options...
