suggs Posted May 25, 2007 Share Posted May 25, 2007 Hi all can someone please tell me were to find the switch, unless i hold the gear lever over to the right when reversing, the lights dont come on. so how do i adjust the switch.. thanks Quote Link to comment Share on other sites More sharing options...
BogMonster Posted May 25, 2007 Share Posted May 25, 2007 on the gearbox there is a screw in switch with 2 spade connectors try adjusting it but it will probably need a new switch, they do break adjust it too far in and the vehicle will jump out of reverse with possible gear damage Quote Link to comment Share on other sites More sharing options...
pinny Posted May 25, 2007 Share Posted May 25, 2007 i had the same prob this was on an r380 box replaced switch not easy to get to but once replaced it works ok there isnt any adjustment on this like the lt77box chris Quote Link to comment Share on other sites More sharing options...
suggs Posted May 25, 2007 Author Share Posted May 25, 2007 thanks think mines the R380 box 96 300 tdi, ill have a look and see if i can find the switch.. cheers Quote Link to comment Share on other sites More sharing options...
pinny Posted May 28, 2007 Share Posted May 28, 2007 thanksthink mines the R380 box 96 300 tdi, ill have a look and see if i can find the switch.. cheers mine was a 96 300tdi i mananaged to disconnect the wiring plug and using a ring spanner to undo switch after passing wires through spanner the switch was about 8 quid from rst at mersea island essex Quote Link to comment Share on other sites More sharing options...
suggs Posted May 28, 2007 Author Share Posted May 28, 2007 mine was a 96 300tdi i mananaged to disconnect the wiring plug and using a ring spanner to undo switch after passing wires through spanner the switch was about 8 quid from rst at mersea island essex cheers, if it ever stops raining ill have a look. rst is that a land Rover shop, not herd of it before im near Lakeside Quote Link to comment Share on other sites More sharing options...
