ltwt1981 Posted June 13, 2007 Share Posted June 13, 2007 Doing a few checks on the Disco 2 last night, have noticed last 2 nights a strange noise when stopping engine, like a hiss, or air in the heater type noise. Anyway a look underneath tells me something is leaking so off with the engine cover, it seems that the heater hose is just about worn through where its been rubbing on the engine cover, I suspect a pin hole at this stage. Good job I looked I'm off to Manchester this week so I'll do it tonight. Is this a common problem on TD5 Discos if so others may benefit from a look. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted June 13, 2007 Share Posted June 13, 2007 The 300TDi will do this as well. There are two forked brackets on the steel pipe that have two of the manifold bolts to keep it in place. They snap with the vibration of the engine and then the pipe rubs against the head bolts and can wear through. Les. Quote Link to comment Share on other sites More sharing options...
ltwt1981 Posted June 13, 2007 Author Share Posted June 13, 2007 This is the rubber pipe just below where it passes through the bulkhead to the heater box. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted June 13, 2007 Share Posted June 13, 2007 The hose on Discoverys around late 2001 build used to rub through on the engine lifting bracket. Quote Link to comment Share on other sites More sharing options...
JST Posted June 14, 2007 Share Posted June 14, 2007 anyone know of similar issues on the def 05? mines loosing coolant but i cant find where from and its not loosing it to the engine sump etc. Quote Link to comment Share on other sites More sharing options...
