nick8556 Posted June 27, 2007 Share Posted June 27, 2007 Does anyone happen to have the gear ratios for the TDI version of the R380 gearbox, just wondering if they are different from the 2.0 litre mpi version? Many thanks Nick Quote Link to comment Share on other sites More sharing options...
BogMonster Posted June 27, 2007 Share Posted June 27, 2007 They probably are, I know the Tdi and V8 boxes have a different first gear ratio, read it in some manual or other a while ago but I don't have the info to hand. Quote Link to comment Share on other sites More sharing options...
paintman Posted June 27, 2007 Share Posted June 27, 2007 You might give www.ashcroft-transmissions.co.uk a call. Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted June 30, 2007 Share Posted June 30, 2007 Mpi: Overall ratios (final drive): In high transfer Fifth ................................................................................ . 4.146:1 Fourth ............................................................................... 4.989:1 Third ................................................................................ 7.518:1 Second ............................................................................. 11.479:1 First ................................................................................ . 17.884:1 Reverse ............................................................................ 18.463:1 The Disco manual seems to only have these ratios in it. This doesn't mean that the V8 and Tdi have the same ratios of course, just that they are not in the manual. It is also shy about the LT230 xfer box ratios: they may all be that standard Disco box. Quote Link to comment Share on other sites More sharing options...
nick8556 Posted July 2, 2007 Author Share Posted July 2, 2007 Thanks Jim I found the mpi ones on rave but can't find the tdi ones Does anyone have the ratios for the R380 TDI box Regards Nick Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted July 3, 2007 Share Posted July 3, 2007 We obviously have the same LR rave manual .... I'll have a look in the Haynes manual (if I can find it). See what that says. Quote Link to comment Share on other sites More sharing options...
nick8556 Posted July 3, 2007 Author Share Posted July 3, 2007 Thanks Again Jim I have looked in the Haynes manual as well and can't find it there either!! Its strange how they will put the ratios for the MPI but not for the TDI ? Regards Nick Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted July 6, 2007 Share Posted July 6, 2007 I have a feeling the main gearbox ratios are the same. The Mpi might use the Defender 1.4:1 transfer box or even the 1.6:1 box as used in the BMW engined 2.8i Defenders made here in SA. It is annoying not to be able to find out. Quote Link to comment Share on other sites More sharing options...
