western Posted October 23, 2005 Share Posted October 23, 2005 Happy to help good luck with the wiring think this might get moved to the tech archive when you reopt back with results B) your 31R above should be 31b Quote Link to comment Share on other sites More sharing options...
Jon White Posted October 23, 2005 Author Share Posted October 23, 2005 Oooops! Finger trouble! Gotta get the wires ordered from VWP but with a bit of luck it should be sorted by next weekend! I'll report back on how I get on! Cheers Jon Quote Link to comment Share on other sites More sharing options...
western Posted October 23, 2005 Share Posted October 23, 2005 Oooops! Finger trouble!Gotta get the wires ordered from VWP but with a bit of luck it should be sorted by next weekend! I'll report back on how I get on! Cheers Jon Nothing less than a full report stage by stage with pictures, will be acceptable Quote Link to comment Share on other sites More sharing options...
Jon White Posted October 27, 2005 Author Share Posted October 27, 2005 Well I dont know about the full stag by stage with pictures as theres not much to take a piccy of realy, but I can confirm that by using the wiring diagram below, and the pin outs below, this works a treat! Does exactly what it says on the tin.......intermittent, slow and fast, and give 4 (or 5 cant remember) wipes when the washers are used. A huge improvement over the archaic wipers and switch gear that are on the series as standard! Highly recommened, but do bear in mind if you're considering this you will need suitable switchgear! Thanks once again for you help Ralph! Cheers Jon Quote Link to comment Share on other sites More sharing options...
Tonk Posted October 27, 2005 Share Posted October 27, 2005 theres not much to take a piccy of realy, not even firemen puttin the flames out or u 'fittin' the relay with a hammer? Quote Link to comment Share on other sites More sharing options...
Jon White Posted October 27, 2005 Author Share Posted October 27, 2005 My wiring is fine - its Nigels thats scary!!!! And not a hammer in sight I might add! Quote Link to comment Share on other sites More sharing options...
western Posted October 27, 2005 Share Posted October 27, 2005 Well I dont know about the full stag by stage with pictures as theres not much to take a piccy of realy, but I can confirm that by using the wiring diagram below, and the pin outs below, this works a treat!Does exactly what it says on the tin.......intermittent, slow and fast, and give 4 (or 5 cant remember) wipes when the washers are used. A huge improvement over the archaic wipers and switch gear that are on the series as standard! Highly recommened, but do bear in mind if you're considering this you will need suitable switchgear! Thanks once again for you help Ralph! Cheers Jon Fitted and working already I'm impressed, happy to help Quote Link to comment Share on other sites More sharing options...
Jon White Posted October 28, 2005 Author Share Posted October 28, 2005 Fitted and working already I'm impressed, happy to help :-).........cant recommend VWP highly enough - faxed my order over one day and the stuff was on the doorstep the next morning! Superb service......... Cheers Jon Quote Link to comment Share on other sites More sharing options...
