JST Posted October 20, 2005 Share Posted October 20, 2005 Well i was tired and had a typo 5 instead of i, but i tshould prove good info for those looking at td5 ones. does anyone have the part number for the LR tdi rev counter? low tension web site i can't get to work. any other suppliers? i seem to remember Warwick Banks doing them in the past, are they still around>? Quote Link to comment Share on other sites More sharing options...
western Posted October 20, 2005 Share Posted October 20, 2005 I used this one genuine LR AMR5724 as fitted to V8 50th & heritage Defenders connected thus ---------------- rev counter terminals marked 2 ---> 'W' terminal on 100amp Marelli alternator +ve ---> ignition controlled feed -ve ---> to earth/ground [any earth cable behind instrument pack] gauge lighting to existing gauges lighting = red/white tracer set 3 slide switches to make rev counter read 750/800rpm at idle & max revs at 4000. Quote Link to comment Share on other sites More sharing options...
simonb Posted October 21, 2005 Share Posted October 21, 2005 Europa specialist parts do a VDO one which fits and is set up the same way as the LR parts one, may be cheaper though. Quote Link to comment Share on other sites More sharing options...
western Posted October 21, 2005 Share Posted October 21, 2005 Europa specialist parts do a VDO one which fits and is set up the same way as the LR parts one, may be cheaper though. I think it's the same, mine has VDO on it's body Quote Link to comment Share on other sites More sharing options...
Neil Marshall Posted October 21, 2005 Share Posted October 21, 2005 I think it's the same, mine has VDO on it's body It is the same. See other thread [TD5 rev counters]......yes, I know you know...... Neil Quote Link to comment Share on other sites More sharing options...
