Source Of Diesel Fuel Hose 56mm
Nick Ninety
In search of some fuel hose. Need about 1m to go from the filler to the tank......
Have a td5 tank in a galv 300TDI chassis and a 300TDI back body. Have used a series filler plate thingy mounted almost above the inlet to the td5 tank. Just need the hose.
Any ideas where i can buy some online or around Chingford, Essex ?
Work really gets in the way as I can't visit any suppliers during the week. Even struggle to get nuts and bolts locally because all the decent places are shut at the weekend.
Thought it was time to start posting rather than just read like I did on the previous forum.
What's the best photo hosting site currently, I'll post some pics.
Cheers
Both the filler and tank look to be about 56mm.
Thanks for the part numbers I'll have a look in microcat. I suspect they may be too short though.
Have one of the stepped hoses off a series filler I think the smallest end fits the tank, but the other is too big and its not long enough.
I'll post some pictures once I have got a photobucket account
OK. here goes, first attempt at posting pictures........
Taken two years so far mostly at weekends. Did have a 6+ month break
Reason I need a non Standard fuel hose, not very clear from picture...
Have got loads more pictures of the build.... Will get a post together over the weekend.
That would be far to easy....
The reasoning behind using a TD5 tank is
1. Better postioning. Tucked out of the way more, not hanging underneath the drivers seat. Hopefully less likely to get bashed or caught up.
2.Plastic, no rust issues.
3. Old tank was knackered and got a good deal on the TD5.
