trr777 Posted August 14, 2007 Share Posted August 14, 2007 anybody know the best/cheapest place to get cv joints from for 1990 Range Rover classic? Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted August 14, 2007 Share Posted August 14, 2007 Depends if you want the absolute cheapest or the best, or the best value... Cheapest is probably going to be Paddocks. Quote Link to comment Share on other sites More sharing options...
Corrode Finger Posted August 14, 2007 Share Posted August 14, 2007 I replaced one of mine last year, think it cost £70 ish. Mine is a 1990, which was abs based, cant remember if that made a difference or not. Just thought i would point it out. Quote Link to comment Share on other sites More sharing options...
trr777 Posted August 14, 2007 Author Share Posted August 14, 2007 I replaced one of mine last year, think it cost £70 ish. Mine is a 1990, which was abs based, cant remember if that made a difference or not. Just thought i would point it out. Mine's ABS too, on reflection I meant best value ( and cheapest )!! Quote Link to comment Share on other sites More sharing options...
stumpy2268 Posted August 15, 2007 Share Posted August 15, 2007 So the lack of right hand lock was a broken CV then ! Try Paddocks, they are generally very competitive on price. I have Paddocks CV's in both my Bobtails, and have not had any problems. IIRC they are about £30.00 each. I'm sure the 'throw it at the scenery with gusto' boys may disagree, but they break everything Quote Link to comment Share on other sites More sharing options...
bishbosh Posted August 15, 2007 Share Posted August 15, 2007 I replaced an ABS CV very recently and had problems with the first one - it was out of tollerance and wouldn't fit into the stub axle bearing. The replacement went in fine. Both were pattern parts around £40 each. A Genuine one is nearly £400!!!. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted August 15, 2007 Share Posted August 15, 2007 I'm sure the 'throw it at the scenery with gusto' boys may disagree, but they break everything It's because they have such huge willies, it stops them from being able to reach the pedals properly... Quote Link to comment Share on other sites More sharing options...
stumpy2268 Posted August 15, 2007 Share Posted August 15, 2007 It's because they have such huge willies, it stops them from being able to reach the pedals properly... So why do they spend so much time and money on ground anchors ? Quote Link to comment Share on other sites More sharing options...
protoprincess Posted August 15, 2007 Share Posted August 15, 2007 because you can't excpect their poor willies to do everything ?!?! pmsl stop it stop it Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted August 15, 2007 Share Posted August 15, 2007 I thought it was because they're lighter for the winch bitches to carry. Quote Link to comment Share on other sites More sharing options...
bishbosh Posted August 15, 2007 Share Posted August 15, 2007 So why do they spend so much time and money on ground anchors ? I'm sorry, but that mind picture has made my eyes water.......... Quote Link to comment Share on other sites More sharing options...
stumpy2268 Posted August 15, 2007 Share Posted August 15, 2007 I think I can see the way this is going, and will therefore apologise to Mr trr777 for highjacking his perfectly sensible thread. Ms Protoprincess - I will be taking some measurements with the inclinometer before returning it, and will report back Quote Link to comment Share on other sites More sharing options...
protoprincess Posted August 15, 2007 Share Posted August 15, 2007 I think I can see the way this is going, and will therefore apologise to Mr trr777 for highjacking his perfectly sensible thread.Ms Protoprincess - I will be taking some measurements with the inclinometer before returning it, and will report back Mr Stumpy, anything less than 45 degrees should indicate a problem! got me skirt and running.... Quote Link to comment Share on other sites More sharing options...
trr777 Posted August 15, 2007 Author Share Posted August 15, 2007 Mr Stumpy, anything less than 45 degrees should indicate a problem! got me skirt and running.... Thank's, I'll try Paddocks then, although I'm curious to know--- what should I pay for a good winch bitch?? Quote Link to comment Share on other sites More sharing options...
